waynefiExplorer IIAug 05, 2022stuck slideThe slide on my brand new trailer is stuck in the out position. When I tried to pull it in, the back end moved, but the front end did not. After a few back and forth tries, neither end moves. My...Show More
mboppExplorerAug 06, 2022You'll need to access the dead motor from the outside, loosen a set screw, and lift the motor up to be able to push the slide in if it's a Schwintec.
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 09, 2026
Related ContentAdding power outlets in slide with no wiringslide stuckSlide Stuck, Awning StuckSlide out stuck?Slide out keeps getting stuck!
