maxum1989's avatar
maxum1989
Explorer II
Sep 20, 2020
Suburban 6 gallon water heater issue
I had a small propane leak at the gas valve on my water heater which resulted in a little fire which melted the gas valve solenoid. I'm not sure what made the fire go out, but the red light came on inside which is when I discovered the problem. No real damage other than some soot and the melted solenoid.
So, I ordered new solenoids (old ones did read bad on a meter) and replaced those. To my surprise it still didnt work.
Here us what I know:
There is propane and proper power to the trailer.
The gas valve works. I have checked it by jumping it off a battery, it clicks just like it should. New solenoids are working. Gas is flowing. In fact I can get the water heater to fire using this hot-wiring method.
There isn't the proper 12 volts running to the solenoid.
The switch inside the trailer is working properly.
My two last guesses are the thermostat switch or the control board. The board is making a faint squealing sound (I didn't notice this before but who knows, maybe it always did that?).
Anyone have any ideas or tips on how to test the thermostat switch or the board?
Having RV issues? Connect with others who have been in your shoes.24,201 PostsLatest Activity: Feb 19, 2025
