KJINTF's avatar
KJINTF
Suburban SF-30 Furnace - Current draw
After a short 15 minute search looking for a replacement 12 Vdc motor for my furnace with no luck. Maybe one of you has been down this road before and could point me in the correct direction
The situation -
Suburban SF-30 furnace with #232682 / 3" 12Vdc electric motor with 6.5 to 7amp current draw.
My desire is to reduce the current consumption, by upgrading the motor, without reducing the air flow (much if at all).
PS - I do not want to change out the heater or add a Cat heater - simply looking for an upgraded electric motor
The existing stock motor is a simple cheaply built brush type, low efficient high current draw with bushings as compared to proper bearings.
Looking for -
A drop in replacement electric motor - with proper bearings and brush-less with <1/2 the current draw.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
