Randu
Sep 03, 2014Explorer
I just went thru the trouble shooting and had spark and good voltage at the gas valve solenoids. Water heater would try to light 3 times. I had ran a brush thru the burner tube and it was clean, no spiders. The one easy thing I failed to check was the actual gas orifice. It appeared clean but I did not run a wire in it to be sure. Replaced the gas valve assembly thinking it was bad. I knew the control board was working due to the voltage at the valve solenoids and the 3 light attempts. New valve and same no light. Decided to take a closer look at the orifice and found it was clogged. Stupid me -- the simplest thing was the cause. Cleaned out good with pipe cleaner and fires right up on 1st attempt with nice strong blue flame. Randu
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
