joebedford's avatar
joebedford
Nomad II
Jan 02, 2024
Solved
Suburban SW12DEL Water Heater On/OFF switch melts???
I know similar threads cover close to this subject, but they're old and don't quite answer my question.
I have a 2011 5th wheel. Last winter (I'm a snowbird) the switch on the heater failed (melted) so I ordered several and replaced the switch. It worked for several months until it was time to go home. When we came back south in December, the electric heater worked for a couple of days then quit. Propane still works. I immediately went to the switch and it was melted so I replaced it again. It worked for exactly one day then quit. I haven't taken the switch out but it's stuck in the ON position - probably melted again.
The old threads say the little switch doesn't carry the full current of the heating element but looking at the Suburban wiring diagram it appears to me that it does:
FYI none of the high temperature buttons has popped, nor the breaker tripped.
Any thoughts on what could cause this? I've already considered that I bought a bunch of cheap switched that can't carry the stated load.
Thanks, Joe
  • How is the wiring connected to the switch? Is there some type of connector? If so, perhaps the connection is becoming loose or building up resistance. Make sure connections are clean and tight too.
  • If you do not have the specifications sheet from Suburban, I would check online for your model. It seems obvious that you purchased switches that cannot carry the heavy current..
    You have a rather dangerous situation with no fuse blowing.
Having RV issues? Connect with others who have been in your shoes.24,288 PostsLatest Activity: Jan 09, 2022
