Ottawa_Campers's avatar
Jul 30, 2018
Suburban SW6DE Problem
Hi all. I am looking for some help diagnosing a problem with my suburban SW6DE water heater. It has worked fine for 12 years but now it won’t run on gas.
When I turn the switch to start the propane burner nothing happens - no light on the reset button, no ticking of the igniter, nothing. I have 12 volts at the switch, the thermostat hi limit switch is fine, and I even get 12 volts at the red wire going into the module board with the propane switch in the on position.
I don’t really know what to do from here, so any advice would be appreciated.
Darryl
  • See what a little troubleshooting/testing does.....finds the problem
  • Update from the OP:
    Based on the advice of Old-Biscuit, I checked for 12 volts at the brown wire on the module board. When there was no voltage there, I still suspected that there was something wrong with the module board, so I removed it and inspected it. There was obvious overheat damage to one of the circuits, so I ordered a new board on amazon.
    Thanks for the help.
    Ottawa Campers
    Darryl
    12V DC on RED wire AT the circuit board means DC circuit is good thru on/off switch, thru set of t-stats BUT nothing from circuit board
    With DC on RED wire at circuit bd then should be DC on BROWN Wire to Gas Valve Solenoids and energizing the spark electrode with high voltage.
    Check the YELLOW Wire coming out of circuit bd..GROUND and needs to be connected for circuit bd to function
    Good ground.then circuit bd is Bad
    Thanks old biscuit. I will check the brown and yellow wires coming out of the circuit board after work tonight.
    Darryl
    Darryl
  • 12 years, nothing lasts forever. Sounds like the ignitor board is done
  • My hi limit switch looked good and even showed continuity thru the wire but it was no good.
  • Around the same age since new, I had to get a new on/off switch that goes by the red light--fixed the problem. Easy swap.
