Angus_NB's avatar
Angus_NB
Suburban SW6DE slow ignition
I have a new Suburban SW6DE water heater.
I use it on 12 volt only.
When I turn on the switch the water heater does light but doesn't seem to light as fast as it should.
There is a small explosion every time. As if propane is building up before it lights.
I've had a licensed "propane guy" check the gas flow, he says it's correct.
Voltage is good, usually above 11v.
What could be causing this? Misaligned electrode or too much gap maybe?
Thanks
