DesertTracker
Oct 22, 2017Explorer
Suburban SW6DE Operation
I typically dry camp, but this weekend had a spot with hookups so I was finally going to get to use the electric function on the water heater. Dry camping is always the gas function. Once hooked up I pulled out the manual which was no help whatsoever. All I have is an on/off switch on the control panel. There is a circuit breaker and a switch on the water heater itself, which has always been off. When hooked to shore power, do I just switch the breaker and switch on and both gas and electric heat the water? Seems simple, but without a decent manual, I just want to make sure I'm not going to break something. This weekend, I just left the switch on the heater and the breaker off and used gas as always. Thanks for any advice.
