wolfwatcher's avatar
wolfwatcher
Suburban W Heater sol. leaking gas
Let me clear that up. I can fire the gas water heater fine, heats, etc. Thermostat shuts flame off, but sol stays energized? I can unplug ground wire, clicks and gas flow quits. Plug back in, and gas flows. Every once in a while the gas switch will red light reset. Gas switch works fine mostly, but the gas leak after flame goes out has been consistant. This sol. stays energized with all switches on electric.
SW10DE. Maybe original, '99 Arctic Fox.
Having RV issues? Connect with others who have been in your shoes.24,190 PostsLatest Activity: Jan 19, 2025
