Veebyes wrote:
Getting behind the reset cover is the only thing not done. Removed the screws but cover did not come off easy so left it. Will do again & be more aggressive this time removing cover now that I have an idea of what is behind it.
As luck has it, a guy with a Mobile Suite, same water heater as mine, has just rolled in. Also has water heater problems. 120V side. Burnt wire behind reset buttons in his. Will try to get back to mine later today.
Thanks for responses. Always good to check with the assembled multitude.
Did you check the wire nut connections inside the DC Junction Box?
Backside of WH Tank (left side looking from back----AC Junction Box on right)
