groundhogy wrote:
The main regulator is 3-4 years old.
It switches between the two 30lb tanks.
The "MAIN" regulator and the Auto Switch over are the same part. You should replace both as a set for best results. Almost ALL replacements are the set, not the regulator and then the Auto switchover valve. A BAD Water Heater Flame will still heat the water but takes a long time. Your Oven/Range has its OWN regulator and that reduces the Pressure from 11.5 down to 10 which is what the Oven runs at. You NEED a Pressure test to make sure you have 11.5 inches pressure. OIL in the LP lines can also cause your problem, but usually affects all LP appliances. Not having a pressure test, you are just left replacing various parts. Doug- What you call the main regulator is the one you should have changed out!
- groundhogyExplorerThe main regulator is 3-4 years old.
It switches between the two 30lb tanks. - groundhogyExplorerThere is propane coming in.
The burners are weak.
The oven burner runs but wife says it was stronger.
Refrigerator running (but isnt that like a very small flame?)
Hot water heater makes hot water - HarvardExplorer
groundhogy wrote:
I swapped out the regulator and NOTHING.
Still the same.
What now?
Do a "Soap Bubble" test for gas flow/pressure at input to the regulator in question.
If no bubbles then troubleshoot "why no pressure".
Has this stove ever worked properly in the past history? - groundhogyExplorerI swapped out the regulator and NOTHING.
Still the same.
What now? - groundhogyExplorerI think it’s looking pretty stong that its the 10” pressure regulator.
I’m going to buy one and try it. - Matt_ColieExplorer IIWhen you get through with the above, lift the cook top and see if there is either a valve or a regulator under there.
If there is a valve, check that it is open and clear.
If it is a regulator, check with the manufacturer to find what the burner pressure is supposed to be and how they advise that you check it.
Matt - Dusty_RExplorerWhat happens if you light one burner at a time, and let it burn for a minute then a second one, then third? Watch to see if the first burner fades when next burner is lit.
- Carl_n_SusanNomad IIYou didn't say what RV you have, but if the stove is in a slide out, check for a kink in the flexible line under the slide.
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: May 13, 2026
