bedpan
Mar 19, 2019Explorer II
My thoughts as well, thanks wnjj..
I will have a discussion with the dealer at some point when I have sometime... The reality is it maybe easier for me to fix the vent, or add supports then the time it takes to hookup and drive 45 minutes up the road twice, to drop off and then pickup. Worth the discussion non the less..
wnjj wrote:dougrainer wrote:
IF the OP is HONEST and tells the Dealer what happened, then odds are the factory will deny any warranty. It is not the dealer that makes the decision on covered warranty items, it is the Factory. The fact is, the OP did something wrong, and he should shoulder blame and cost. Doug
There's nothing wrong with filling the black tank with fresh water, even if through an non-standard means. The flow rate of the hose should be easily offset by the vent. If it cannot handle being full of water with 5 psi, it never will when travelling down the road.
Having RV issues? Connect with others who have been in your shoes.24,367 PostsLatest Activity: Mar 10, 2026
