k1hog's avatar
k1hog
Supply Propane from RV to Grill?
From the propane tanks on our TT is a distribution block where several propane lines are connected to hot water heater, frig, heat.
There is one port that is plugged.
I would like to connect a propane hose to this plug, so that I could run the baby Q grill. The distribution block is regulated propane, at the baby Q is a regulator, which means the line from the distribution block to the baby Q would be regulated two time.
Will that work?????
Thanks Johnnie
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
