kenair's avatar
kenair
Surburban SW6DE Hot WT issue, fix, and I have a question
I tried firing up my Surburban SW6DE hot water tank today on gas, the ignitor was clicking but no flame. After a dozen on - off turning the switch on - off cycles I gave up and came in to search the web, web posts said likely bad gas valve Went back out, still no joy.
I decided to look inside the interior compartment where the HWT tank is mounted, and found this loose green wire, I shoved it back in the plastic connector, turn the tank on and it fired on the first try, big joy!
QUESTION - what are those round plastic connectors, are they just fancy butt connectors?
cheers - ken
1 Reply
  • j-d's avatar
    j-d
    Explorer II
    Yes, fancy butt connectors
    We used something like that at the phone company. They do the same function as a ScotchLock connector, the kind that pinch through the wire's insulation to make contact. Difference is, they contain a "gel" or "grease" perhaps Vaseline, to seal moisture out of the connections. This should prevent them from failing due to corrosion.
Having RV issues? Connect with others who have been in your shoes.24,341 PostsLatest Activity: Dec 07, 2025
