MrWizard
Jul 19, 2018Moderator
i'm sure the Sola he has is NOT automatic
it can do boost or buck
but it has taps and you manually set it for the amount of boost or buck
he has detailed this numerous times
he has it on boost (i forget the amount) if line voltage suddenly went up
so would the voltage to the RV, thus an EMS is needed
the same if the voltage went too low the Sola would continue with the same amount of boost, and the RV voltage would be TOO LOW
Having RV issues? Connect with others who have been in your shoes.24,398 PostsLatest Activity: Jun 28, 2026
