T_bone1's avatar
T_bone1
Explorer II
Jun 05, 2017
Surge Protection
I have been using surge guard model 44270, today I purchased a model 35550. I am not sure what the big difference is, neither is resettable after a surge. Must be replaced.Am I missing something?
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    Ok the one you were using is nothing more than a spike suppressor, and yes spike supression does wear out over time and multiple "Hits"
    The one you have now (the 34850) not only offers spike suppression, which by the way can be easily renewed. but high/low voltage suppression, time in (Which is an additional form of protection) and more It is the model I have as well.
    Spikes are short (Usually less than 1/60 second) rises in the voltage.
    But low voltage is often more damaging. trying to start an A/C at say 100 volts, can damage the motors big time at 1,000 to replace.
    Likeise folks have been known to plug into an 240 volt outlet (30 amp) thinking it was a 120 volt. ... again the unit you now have with the LCD dislay will protect you (The older one would not) and inform you. This too can easily cost thousands if you do not have protection... Short story at end.
    Finally the "Time in".. I have been through several power failures. when power fails and is restored.. Many A/C's and other heavy loads kick in.. Well the power line voltage goes on one heck of a rollar coaster ride. again this is damaging.. Lasts, generally less than a minuite. but since it takes nearly 3 minutes for your new surge guard to pass power.. YOU ARE PROTECTED,
    This is a very well built unit. works well but .. Only a 1 year warranty
    The PI units are also very well built. Work well, and come with a lifetime warranty.
  • The Model 44270 is the entry level portable 50A surge guard.
    It tests for and INDICATES power, Open Neutral, Open Ground, Reverse Polarity etc BUT does NOT have Hi/Lo Voltage trips/auto reset and will still allow power even with other faults indicated
    The Model 35550 is te high level hardwired 50A surge guard
    It tests AND TRIPS HI/LO Voltage, Open Neutral, Open Ground, Reverse Polarity etc.
    This model is much better then the 44270 one BUT-----
    Both are NOT field/factory serviceable and only have a 1 yr limited warranty.
    When 'broke' they are disposable
    Progressive Industries Surge PROTECTORS are higher level protectors and are serviceable/repairable with a LIFETIME warranty.
  • Consider moving to an "intellegent" EMS (electrical management system). Progressive Industries makes 30- and 50-amp models in both in-line and hard wired. They protect against all sorts of things such as spikes, over- and under-voltage, polarity issues, ground faults, etc. The systems will take your rig off-line and will reconnect when the issue is resolved. We wouldn't be without one.
    Rob
Having RV issues? Connect with others who have been in your shoes.24,390 PostsLatest Activity: Jun 05, 2026
