Hi all, I purchased a swamp cooler and today ran it for the first time. The RV had been sitting in sun all day long with the fantastic fan on high, with the rear roof vent open. Temperature outs...
As it gets more humid, you feel warmer. That's called a heat index - it tells you how warm it feels, which is different than the temperature. There are calculators which make it easy to figure out. I just showed and compared the results based on what you reported. e.g. 88 degrees @ 33% RH = 86 degrees (heat index).
