Chris_Bryant
Jul 30, 2017Explorer II
The pilot gas valve needs a boss on the tank for the temperature probe-
The electronic tank doesn't have the correct setup.
Just measure the voltage at the valve while it is sparking- if it's above 12 volts, everything else is fine. If not, go back to where the voltage stops.
You might also try giving the valve a sharp whack while the spark is firing- if it opens, you will still need to replace the valve, but at least you will now what it was.
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 13, 2026
