Gdetrailer
Jul 30, 2017Explorer III
upuaut wrote:
Orifice is not damaged. I'm not about to spend money throwing parts at it unless I'm sure it will fix the problem.
Judging from the aged look in your pix the tank is not "new" by any means.
I suspect the gas valve is bad. Sometimes the solenoid is the problem but most likely in your case the plunger is stuck or the valve the plunger moves is stuck.
Pretty much anyway you cut this, it is not a cheap fix.
Since the tank is not real new, replacing it is a no brainer rather than randomly tossing money at it.
Pilot only tanks can be had for $260 or so.. Much cheaper than DSI models and dead on reliable instead of that pesky solenoid valve (my Dad had problems with his DSI solenoid valve).
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 13, 2026
