MRF's avatar
MRF
Switch for cooling fans
Hello All:
I just joined the Good Sam Club and RV.NET. This is my first post.
This is also my 1st RV experience. I bought a used RV from my friend and am getting a considerable education, rather quickly. I have been hit with some mechanical and electrical surprises and even a refrigerator fire, at the RV service center during a de-winterization service (and yes, we are still friends). I can't wait to use this thing!
My electrical components are sitting directly below my refrigerator. I sealed all the necessary areas and installed vents with 120 mm computer cooling fans to force cool air across my electronics and up across the back of my refrigerator area, then exhausted through my roof vent with another fan. My power source is the 12 V refrigerator wiring. For right now I do not have a thermal switch, just a SPST, 2 terminal, On, Off toggle.
I am an electrical neophyte and don't want to take any chances in the RV electrical arena, of which I have no experience. You would think wiring a simple toggle is a simple task, however I have read numerous blogs and posts, some saying connect both wires to the back of the toggle, some saying place the power wire on the toggle and run the other one to an independent ground and one with no mention of ground at all.
Which is correct????? That is the 1st question.
2nd question: Do you think I should put in an in-line fuse?
Any input would be greatly appreciated.
Thank you
MRF
  • Chris Bryant wrote:
    I may be misunderstanding this statement, but it sounds like you have opened up vents between the bottom of the refrigerator and electronics beneath it. This is a very bad idea- the base the refrigerator is sitting on must be sealed and vented out the side- assuming we are dealing with a standard gas/electric model. LP gas is heavier than air.
    That is true. In case of a propane leak, you'd want the gas to vent to the outside, not the inside.
    Good catch!............THANK YOU FOR THAT INPUT!
    I did not think of that. It is only blind luck that I am safe with my present set up.
    You are correct in the venting, but I failed to clarify; I am temporarily using an apartment size, electric only fridge. Once this new RV experience/experiment is underway and if it becomes a regular part of my lifestyle, I will remove a couple of my modifications and pony up the $$$$$$ (ouch) for an RV fridge and install it properly, to include a correctly sealed and vented area. Everything I have done is easily reversible or alterable to accommodate an RV technology fridge. I already have a second cut and sized drop in floor. I will reposition the bottom fan for the electrical only (5 min), redirect the middle fan (5min) to cool the refrigerator rear area, only and leave the roof fan as is.
    I am still licking my financial wounds from $6000 worth of surprise expenses in an RV I haven't even used yet, so I didn't rush to pay $1500 to $2000 for a new Norcold or Dometic.
    (Insurance would only pay for the resultant fire damage, but NOT the fire source, which was the refrigerator. I am in the process of trying to get the cost covered through the insurance company's subrogation with Norcold.)
    I just updated with some clarifying info. I think I am OK for now.
    BTW, an RV dealer and service center capped my gas line and I had it checked for leaks.
Having RV issues? Connect with others who have been in your shoes.24,188 PostsLatest Activity: Jan 17, 2025
