tenbear
Mar 12, 2015Explorer
Did the 12v system work before you went into the boonies?
Do the coach lights work with the engine running? That's when the alternator and chassis battery are connected to the coach battery. If the lights work it could indicate that the coach battery is dead.
If you have a multimeter or a test light, start at the battery, follow the wireing, and see where you loose the voltage.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 05, 2026
