Bowcamper's avatar
Bowcamper
Swith Panel I.D. Help!
I have a 04 Skamper Kodiak K160. Under the dinette are switches for the controls. Only one is labeled, (water heater). There are two that I do not know what they do. If I knew how, I could post some pictures so you could see what I am referring to.
Anyone willing to help? Any suggestions?
Thanks!
  • Thank you so much! That's the first set of answers that I ever had. I have never been able to receive any feedback nor could I find any reference in any manuals. What you have said, makes sense. Now to trial and error on your hypotheses...
    Any further thoughts or observations -- keep them coming.
    Thank You
  • DrewE wrote:
    The red light one might be a 120V element in the water heater. It looks like it's probably a 120V switch (rather than a 12V switch). It could be most anything, though.
    The little lone one next to the water heater looks more like a 12V switch. I would guess it's either some lights somewhere (maybe in the outside storage compartments) or a water pump switch. Again, it could be most anything.
    You might be able to trace wires...though that's not often an easy task.
    That's my take- 120 volt water heater, and water pump.
  • DrewE's avatar
    DrewE
    Explorer III
  • I believe it was one of the rv.net moderators that created the link below to help with posting pictures. It works great.
    At your home screen, right click, select new, then shortcut. Copy the link below as the location, select next and give it a name like RVnetPhoto, then select finish. This short cut will take you to the picture hosting site quickly any time you need to post a picture.
    I keep it on my home screen next to my rv.net short cut.
    To post a picture, double click your newly created shortcut "RVnetPhoto". Drag the photo you want to post to the host window and drop. It will return a link. Just copy the link and past it into the rv.net message window.
    You'll get the hang of it after a few posts.
    http://dl.dropboxusercontent.com/u/201045551/Forums/PhotoUpload/RV.NET-Photo-Upload.html
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
