SFVdave's avatar
SFVdave
System upgrade for Lithium coach batteries issue
Looking at upgrading my system to Lithium coach batteries. My system currently has a PD4560 converter charger and a Precision Circuits BIM allowing bi-directional charging to both coach and engine batteries, all batteries are flooded acid cell.
Under new upgrades with Lithium coach batteries, the PD4560 would have to be changed to PD4560Li which no longer has the charge wizard and equalization mode and provides the 14.4v constant. This will cause an issue with the Precision Circuits BIM which allows bi-directional charging and engine battery boost function. The PD4560Li converter charger manual states "DO NOT USE WITH FLOODED ACID CELL BATTERIES" for obvious reasons of charging parameters.
There is an expensive upgrade for the Precision Circuits BIM costing $500. Wouldn't just disconnecting engine battery from the BIM and isolating it work? Battery cable from engine battery goes to a fuse box first before running back to the BIM and is easily disconnected. This would provide engine battery charging, but no charging to the coach batteries while driving. However, I have 300 watts of roof top solar which would be charging the coach batteries. I'm not sure what's tied to the engine battery to draw it down. The dash radio with CD, DVD and navigation is wired to the coach battery and No power steps.
Has anyone encountered this situation and if so what was your solution?
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 01, 2026
