Benderman's avatar
Benderman
T-stat mod. Why does a/c fan run when furnace is on
I saw this question in a previous closed post. None of the answers solved the problem for me. What did work was to flip the switch (inside the t-stat) from "gas/oil furnace" to "electric furnace" - and then switch it back. Also need to set the heat anticipator to 3 (as the previous post suggests)
When I did this, I tried the t-stat in " electric furnace" mode...then switched back to "gas" mode - and the a/c fan quit coming on in heat mode. I mention this because it may not be enough to just flip the switch and flip it back - and it may be all it takes. If not you may try
- flip the switch to electric furnace mode, try to run furnace, then switch back.
- or; flip the switch to electric mode, wait 5 minutes, and switch back to gas mode
- or; flip to electric mode, remove and replace batteries, and switch back to gas mode
I'm not an electrician. So I don't know what exactly what is happening, or why. I just know I was having this problem and fiddling with these switches, after double-checking that my wiring was right, solved it
Hope this helps. Saved me from scraping my $25 digital Hunter t- stat and having to buy the Domitan replacement for over $100 --- good luck
Moved to Tech Issues forum from DIY.
1 Reply
  • If the "Fan" switch is set to "On" it will do as you describe. This switch must be set to "Auto" for everything to run properly.
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: Nov 08, 2021
