dgrimes80 wrote:
Thanks everyone for the help. I replaced the bulbs and it popped the fuse when I turn the turning signal on. Should I assume at this point that I need to run new wires for the tail lights?
That would probably be the best solution because you'll know that you have good wire and good connections to the lights.
Tracing a wiring fault to the back of a travel trailer can be a hair-pulling event. There are a lot of places where a short can develop or a wire is nearly parted within the jacket, unviewable by visual inspection.
FWIW, when I restored my trailer and replaced all the wiring, I soldered and heat-shrinked any splices. I engineered in one spot that has the 4 wires exposed inside the trailer, aft. If I have a wire issue, I'll at least be able to partly trace the fault. If I was blowing fuses, the only solution would be replacement and I would pull wire through either a hose remnant or flex conduit, fastened to the underside of the trailer.
Good luck with your light issue.
