NinerBikes
Aug 24, 2015Explorer
Old Red is a pretty common charger, it's probably a manual charger, and generally speaking if it's a 6 amp charger and you get it down to a 2.5 to 3 amp charge rate with your gel cells, you are darn near fully topped off. Pretty typical for this type of charger.
We've no idea what the amp hour capacity is of your shaved ice machine gel cell batteris by MK. Would be quite useful.
I am going to default, as I have no experience what kind of bulk charge or float voltage or amp capacity MK batteries for an unknown model shaved ice machine needs. It's usually determined by the battery manufacturer, so look up your Model MK batteries on line, and see what the manufacturer suggests.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
