- ol_Bombero-JCExplorer
theoldwizard1 wrote:
MrWizard wrote:
stand alone inverters do NOT charge batteries
combo inverter/charger ... will charge batteries when 110vac is available either from shore power or generator power, ...
they do not charge from alternator while driving
that is a separate function of your chassis/engine electrical
are you thinking of TV and laptop and cellphone chargers ? 300w
or coffee maker and microwave 1200w to 2000w
Spot on with all of these statements. I will add a couple of comments.
• To make life (and wiring) less complicated, look into inverter/chargers with a built in automatic transfer switch. Some come with inputs for shore power AND generator power and can even start your generator. Check out Samlex EVO inverter/charger/transfer switches.
• Read this about charging while driving (DC-DC battery charging).
OP - dyno-mite! - You rated.....a pair of Wizards!..:C
~ - 1LongbowExplorerThanks to all for your answers and help
- theoldwizard1Explorer II
• Read this about charging while driving (DC-DC battery charging). - SidecarFlipExplorer III
MrWizard wrote:
1Longbow wrote:
I don't know much about them .old one was 1750 amp? Just thinking, that needing to replace it ,should I just go bigger. The old one did everything I need i guess.
that would be 1750-watts
if it has quit working, either inverting or charging
and you want to replace it ?
then 2000w Pure Sine Wave aka PSW
will do everything the 1750 did and have a little more power
IF for some reason the old just seems like it is still working but not as good as it used too
think about getting your batteries and the wiring connections
checked out, ... before spending money on a new inverter
it might be old worn batteries ?
new batteries could cost you more than a new inverter
be sure what you need before you spend the money on a new inverter
then find out you still have a problem and need new batteries
Good advice. Why throw money at something when the end result might just be a lightened wallet and no improvement. - AlmotExplorer III
AllegroD wrote:
I woould suggest you see dependable professional.
This. - AllegroDNomadFor upgrading and invereter/charger, what size wiring you have is important. I woould suggest you see dependable professional.
- KD4UPLExplorer III would only look at pure sine wave units, I wouldn't mess with modified sine wave. You can get excellent inverter/chargers in several sizes from Magnum. Also I think Outback still makes a 12 volt mobile model, The FX2012MT. Either of these manufacturers should serve you well. I think Samlex also makes some inverter/charger units now but I haven't used one of them. I have experience with numerous Samlex inverters and have been very pleased with their performance.
- MrWizardModerator
then find out you still have a problem and need new batteries - AlmotExplorer IIIWhile driving you need DC input from alternator - not AC from inverter.
Inverters are in watts, not amps.
Ipad and phone: any small inverter. 100W will do.
Coffee Maker: 800 to 1500W, depends on what coffee maker.
Microwave: 1500-1800W, depends on microwave.
Everything together - do the math. There are limits to what a battery bank can handle, too. - BFL13Explorer II1750 Watts was a common size of Xantrex MSW inverter 15 years ago. Some newer ones other brands that size too. It can run a microwave if strapped to enough battery bank and the microwave is willing to work on MSW.
There are smaller and bigger coffee-makers. Depends on watts size if the 1750 will do it. You can't run them both at the same time!
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
