huskyfan68ExplorerJun 10, 2014Tank valvesmy 05 Durango has the gray/black valves mounted inside a compartment- The valves then have a long cable which runs to where the tanks are. The valves feel like they don't close all the way any longer ...Show More
Dave_H_MExplorer IIJun 10, 2014If a black valve does not close all the way, you will have a constant run, drip etc of the stuff from the black tank.If you have an enclosed under belly and X ray vision you can cut a flap in the right place, replace the valve, and seal it back up.If your vision is not X Ray, you under belly will look like mine.
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,284 PostsLatest Activity: Jul 17, 2025
Related ContentBlack tank valveBlack tank new valve locationPropane tank valve - stuck solidTank drain valvesAutomatic air tank drain valves
