milo's avatar
milo
Explorer II
Jul 10, 2014
Tapping into the 12v Electrical
Good Morning. Our 5er does not have a gravity flow opening for the fresh water tank fill. So to fill it, I have to hook a hose to the water inlet and select tank fill and find a water spigot to add water to the tank.
My question for all you electrical experts out there ... I have a 12v pump I can use to pump the water into the FW tank. What would be the best way to tap into the 12v electrical that runs under the slideout about 3 or 4 ft away. The wires are covered with that protective corrugated plastic covering. I'm trying to figure out the best way to add wires & a plug so I could plug the pump into it when needed to add water & unplug it when not using it or on the move. Need a type of setup (wiring & plug) that won't get all screwed up from the road elements. Any suggestion on what would be the best way to tap into those wires & what type of plug.
Thanks
Milo
