JoeH's avatar
JoeH
Explorer III
Sep 20, 2019
Tecma Toilet impeller issue ?
My rear bath toilet is not flushing. I am thinking the impeller is toast as I hear the motor spinning, but no flushing occurs. Just wondering if anyone has taken theirs apart and if there are any precautions . Good thing is there is nothing but water in the toilet so I don't have to worry about that aspect, other than sponging out the water before removing it.
  • JoeH's avatar
    JoeH
    Explorer III
    The LED is green.... I can hear the motor run when I push the button, but the water stays in the bowl. I'll look at taking it apart in a few days , just don't know if there are parts available as the manual I've seen just have the motor assembly, not the individual parts like impeller and seals.
  • In case you don't have it
    Tecma Manual
    Just thinking, my Sanicon Turbo 600S mascerator does that sometimes, it's the same motor and impeller as the Tecma, I shake it and turn it on it's side and it clears. I have two Tecma toilets. What color is the toilet LED?
  • I had mine do the same thing once. In my case, somehow the main "drain" hose got twisted enough to essentially pinch off the flow - like a kink in a garden hose.
    I re-adjusted the hose and re-tightened the clamps and it's been fine since then.
