1969SSCamaro's avatar
1969SSCamaro
Tekonsha Prodigy Wiring: Brake Light Signal
I have a 1995 P30 (Georgie Boy - 27') and need to connect a Tekonsha Prodigy brake controller. One of the signals is STOPLIGHT, which tells the brake controller it should engage. I found two switches that operate when the brake pedal is pressed in, but the only signal I could find that transitions to 12 V is also active when the hazard lights are turned on. Using this signal seems like a bad idea, especially if I am going up/down a steep hill and want to use my Hazards. Anyone have any other options I could investigate or wired a similar brake controller?
1 Reply
  • I found another post where a relay was used to convert the negative going signal to positive. After further verification I discovered that I have 2-3 negative going signals; when brake is engaged, the signal transitions from +12V to ground. I will pursue this approach to complete the wiring.
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: May 13, 2026
