MNtundraRet
Nov 29, 2015Navigator
road-runner wrote:My 32" Insignia LED TV uses around 25 watts. My clamp -on meter registers about 4 amps per hour of use.Sorry I don't know how to say this without sounding crabby. Don't mean it that way. "4 amps per hour of use" is meaningless. "Amps" is an instantaneous measurement. A rough water equivalent statement would be "4 gallons per hour per hour". 25 watts suggests a draw of about 2 amps at nominal 12 volts, which would result in using 2 amp-hours per hour from the power source.
My TV and a second RF amplifier run off a separate battery when off grid. Any amp reading is instantaneous but means 4 amps per hour when done without any changes in usage. So what's your problem?
I have been doing this way since the eighties (different TV,s, inverters, etc.,) without ever running down batteries. As mentioned earlier TV power needs change with how the TV options are set up for watching. Using a clamp-on meter at any given time is best way to make sure you don't deplete your battery.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
