SkiSmuggs
Dec 01, 2015Explorer
tenbear wrote:
My 22" TV draws 1 amp at 12v. It had an adapter, 120vac to 12vdc. I removed the adapter and run the TV directly off 12vdc.
Perhaps you could find an appropriate sized TV with an adapter to remove for smaller current drain. :h
My new Samsung 32" has a power brick. I need to check the output to see if I can just get a 12vdc cord for it. Thanks!
