NinerBikes
Dec 02, 2015Explorer
MNtundraRet wrote:NinerBikes wrote:
14.4V on the Samsung brick, if it's like my 24" model
You bring up an important point.
Most people assume the power brick will convert 120V,AC, to 12V,DC (TV would need to operate down to around 12.0 volts).
Not true! Most newer televisions require 13 to 15 volts DC.
Since fully charged RV batteries are only 12.6 to 12.8V (depending on type) they will fail to run the television, or only for a short time.
The only method that is sure to work is to use an Inverter connected to your battery-bank to supply 120V,AC, and plug in the brick. The television will get the correct voltage. Using a smaller inverter will have less overhead and give you a longer time on battery.
Before switching to HD TV in 2006 (for RV), I had a 9" TV, labeled 12 volt type. After reading manual I found in the specifications that the television needed a minimum of 12.5 volts to operate. That in reality was only about an hour or two of television before the picture failed.
That's when I purchased my first 300 amp inverter. Television worked just fine after that.
Get a buck booster, and correct for 14.4V. Drok buck booster. See Salvo's current thread on the subject.
