WDE's avatar
WDE
temporary loss of 12volt power when turning off lights.
I am having an issue with my 2005 Forest River Salem fifth wheel.
On our last trip, the 12 volt system started going completely off at times when we would turn of a light or otherwise change the load on the system.
The 12 volt system would then stay off for approximately 3 - 5 minutes then start coming back on with the lights starting out dim and then returning to normal.
We were hooked up to shore power and I camp with the coach battery disconnected (not charging) and running the 12 volt system off the converter.
I had to connect the coach battery to prevent these loss of power episodes.
Bad converter ???
Any ideas as to possible cause?
I have used this camper this way for years (coach battery disconnected while on shore power).
Any help appreciated.
  • either a bad connection somewhere
    OR
    yes , bad converter
    check the connections between the converter and the battery
    clean them and tighten them
    especially the Negative ground connection
    if that doesn't fix the problem replace the converter
    BTW FYI most converters are Not designed to be stand alone power supplies
    they are supposed to be connected to the battery
    especially for high current loads, like Jacks and slides
  • Thanks for the help
    I had read something about the load supplied by the battery.
    It may have taken this long for it to become an issue with the battery disconnected.
    Going to try and limp the converter along by using battery connected.
  • There is likely a self-resetting circuit breaker that is failing. It could also be a component on the converter's circuit board or a combination of both.
    When the converter is powered and the battery connected, the battery provides capacitance in the 12V system. The capacitance allows the converter's output and internal charging circuit to run "smoother". I'd suggest you connect the battery when using the converter and your 12V system. Monitor electrolyte level in the batteries if you have FLA batteries.
    This battery filler makes maintaining batteries easy.
