opnspaces
Oct 25, 2021Navigator III
This is a simple test that will tell you if your charger works. But not how well or efficiently the charger works. Unplug your shore power and run the furnace blower for 2 minutes to pull any surface charge off the batteries.
Put the volt meter on DC volts. The DC volts symbol looks like a solid line on top with a dotted line under it. If there are multiple selections for DC volts then put it on 20v or the closest reading that is more than 12.
Measure the voltage at the batteries. Then plug the RV in and measure the voltage again. If the voltage increases you are charging.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
