- JimK-NYExplorer II
fourthclassC wrote:
Howdy Folks, small disclaimer here - I work for the company - but a good solution is the PUR faucet mount with the quick disconnect feature. Activated carbon filter with bacterial cyst, lead, and many other contaminants removed. Best thing is that it is right at the point of use so it removes contaminants right before using the water. And very easy to disconnect before travel.
Since you work for the company perhaps you can learn from one customer's experience. Years ago I tried one of these Pur faucet mount units. It was made of cheap plastic and soon leaked. Replacing the filter without breaking the unit was also about impossible. I returned it and got a replacement.....twice. Since then I have used a Brita jug and filter. - fourthclassCExplorerHowdy Folks, small disclaimer here - I work for the company - but a good solution is the PUR faucet mount with the quick disconnect feature. Activated carbon filter with bacterial cyst, lead, and many other contaminants removed. Best thing is that it is right at the point of use so it removes contaminants right before using the water. And very easy to disconnect before travel.
- Dutch_12078Explorer IIIWe've used Aqua-Pure whole house taste and odor filter cartridges for years to get rid of the chlorine taste. It also filters 5+ micron rocks, rust, etc. We use our tank water for everything including drinking, and have never suffered an illness traceable to the RV water supply.
- Edd505Explorer
Old-Biscuit wrote:
Use the Blue in-line filters all the time......have done so for many years
Use fresh water tank for everything...cooking, coffee/tea, washing, showering, teeth brushing and DRINKING.
Fresh water tank is just a big ole water bottle
Water that goes in it is from city water supply..just like at home
S&B water is not filtered to remove TDS etc
RV is just like S&B.....
Folks sure do like to make RVng complicated :H
That would be why I buy RO water to drink at home, not all water systems are the same. RO water is no matter where I get it, 2 gallon dispenser on counter & 3 3gallon bottles. - sorenExplorer
JimK-NY wrote:
I have used my RV for hundreds and hundreds of nights over close to 10 years. I have never filtered the water. Only once did I encounter a problem. The water was cloudy and I did not use it. I think it had been tested and was safe but I did not want the silt in the tank and lines. I guess a filter would have been useful for that situation, but I think avoiding the water entirely was a better choice.
You can spend a lot of money on water filtration devices. Some of them even remove chlorine, which is a really bad idea. Instead I just use a Brita for filtering drinking water.
I installed a separate tap and large commercial grade filter at my kitchen sink in the motorhome. This allows me to end up with relatively clean and chlorine free water for ice cubes, drinking and coffee making. Works for me The cartridges are about $40 and get swapped once a year. Since the wife will not use city "swimming pool" water to make coffee, this setup is a lot cheaper than buying gallons of spring water. - beemerphile1ExplorerI use an ordinary sediment filter for all incoming water and a .5 carbon filter at the sink for cooking/drinking water.
In my opinion those blue Camco hose filters are a waste of money and on top of that you don't want to remove chlorine/chloride prior to the tanks. - GdetrailerExplorer III
wopachop wrote:
Thanks for those links tech writer!
My RV has all types of stuff non RV brand. Been doing remote control dimming leds for many years. Built myself they rock.
Took a marine blower, attached a car filter, and mounted that on the frame. 4" landscape pipe for the ducting.
Love stuff like that.
Will step it up to a real filter when the camco dies.
Good plan.
Just realize that if you are not drinking the water there is no need to worry about dissolved solids, they will stay dissolved and not settle out in your freshwater tank or lines.
Non dissolved solids however can be an issue, these types of materials tend to fall out of the water and coat everything in it's path..
If you have the water I have, you WILL understand the ramifications of this issue..
My home water has such a high undissolved iron content, it comes out of the ground looking like red mud! It lines the water pipes and coats valve seats and basically grinds out any valve or moving part in the water flow unless I prefilter it first then hit it with water softener.. Prefiltering allows me to skip iron removal so only a softener is needed to remove the remainder of that the prefilter didn't catch.
For the most part, unless the campground is super primitive a simple whole house filter like I linked should suffice. - wopachopExplorerThanks for those links tech writer!
Will step it up to a real filter when the camco dies. - GdetrailerExplorer IIILooks like this?
Ditch it!
Expensive use once and toss filter.
It IS NOT designed to remove DISSOLVED solids, never was and never will.
It is solely designed to stop NON DISSOLVED (sediment) particles in the water (IE mud, dirt, sand) and if it has charcoal perhaps things that cause off taste like Chlorine.
For sediment instead of using those high priced Camco filters you can use a WHOLE HOUSE replaceable cartridge filter system.
Like this..
Which you can buy 3/4" pipe to hose bib adapters to connect your hose to and takes filter cartridges which are much cheaper..
String or yarn wound filters can be had for $8 for two and could be removed and dried safely then reused multiple times in your case if that floats your boat.
The advantage is the filter system poses no reduction in water flow (3/4" inlet and outlet) and the filters are much more cost effective than the one and done Camco.
I use this type of cartridge filter as a prefilter for my home water softener system, blocks the mud, dirt and larger iron particles from getting into the water softeners valves preventing the valves from wearing out..
Not everything you use in a RV MUST come from a "RV" brand manufacturer.. - TechWriterExplorer
drsteve wrote:
wopachop wrote:
I ran about 150 gallons through the filter and then checked the total dissolved solids.
Garden Hose: 94, 97, 100, 98
Camco filter: 98, 104
Reverse Osmosis: 23
RO 23? You need to replace the membrane. Should be low single digits.
Depends on what you start with . . . raw AZ water measures between 700 - 800 on my tds meter.
And as others have mentioned, Camcos filter our rocks. That's it. They don't lower total dissolved solids levels or remove minerals, chemicals, viruses or bacteria.
Either use an RO system for drinking water or for just your water tank, use a quality sediment filter with a clear plastic housing.
Why clear plastic?
So you can see when it's time to clean the filter . . .
Having RV issues? Connect with others who have been in your shoes.24,283 PostsLatest Activity: Jul 17, 2025
