path1's avatar
path1
Testing propane alarm in more life like conditions?
Sometime ago after a long walk we came back to RV and the odor of propane was very strong and alarm did not go off. Turns out old alarm was 6 years old, so time for a new one. New alarm tests “OK” following the manufacture instructions. But I still want to perform somewhat of a more real live test. My first thought was turning on the stove and seeing if and when new alarm sounds off. Then I thought a much more controlled test would be better. I’m thinking about putting it in BBQ (outdoors) using spare battery and a couple leads for power and closing the lid and turning on the gas. I don't want to depend on the same manufacture who's alarm did not go off and also using their "test" button. More of a life like test would be better IMO.
Any thoughts? Good, bad, got a better idea or whatever?
We (wife and I) think I must of turned on the stove when putting my jacket on by mistake, going out of the door. Maybe my hand turned on the gas when sliding my arm down the sleeve putting on jacket? This has never happened to us before and think that is the only thing we think it could have been. My stove knobs have to be pushed in just a little and turned, probably like most stoves. We believe this was a fluke thing.
But as we’re laying in bed at night it still goes thru our minds that the alarm has not been tested "in real life"
Thanks
  • We have been told by various LP detector makers to NOT use any BUTANE based lighter or such to test the LP detectors. Use ONLY an LP based vapor to test them. Doug
  • Almot's avatar
    Almot
    Explorer III
    Well, you can make a real life test if you like. Disconnect the propane sensor, take i off the wall or wherever it's sitting, put it in some barn and connect 12V. Bring a 20lb tank and open it slightly for half an hour. Just make sure the barn isn't full of firewood :)
  • Butane test sounds good for actual function- any bic/flick type lighter would do the trick. But if it's "real life" conditions you want to test for, I don't see any better than the one you already propose: turn gas on, shut door, and wait for the alarm. The timing would certainly be interesting...
    But do make sure you've shut everything else in the vicinity down first, and stand there with your hand on the tank shutoff valve!
  • I had a tech test mine by using the gas from his butane lighter. It worked.
Having RV issues? Connect with others who have been in your shoes.24,210 PostsLatest Activity: Mar 04, 2025
