rockcandymounta's avatar
Jan 29, 2021
%th Wheel Batteries
How can I check to see if my electrical system in my 5th wheel is charging the batteries?
My unit is a 2016 and after being in storage all winter and plugged into shore power, when it is not plugged in and I go to use the electrical leveling jacks, I get a low voltage error.
If the batteries are bad, I will replace them, I just don't want to do that if they are good. I keep the water level topped off. But I suspect the batteries are just worn out.
  • While in storage, the disconnect switch is set to "off". Once a month, I recharge by running Honda generators for about six hours. That's not scientific (I don't know how much time is required for a full recharge), but it seems to work. It has the added benefit of exercising the generators.
  • Do you disconnect a battery cable to isolate the fully charged battery while in storage? Otherwise the battery will most likely overly discharge, sulfate, and lose capacity.
    The 12 Volt Side of Life
  • Digital Multimeter..
    HERE for $7..
    Set to 20V DC on the meter.
    Plug red lead into meter socket marked "V" (the middle one)and the black lead into the bottom meter socket.
    Turn meter on.
    Place red lead on POSITIVE battery post and black lead on NEGATIVE battery post.
    Battery resting voltage hen fully charged with no load and charger/converter is turned off should be 12.8V or a bit better..
    With converter turned on you should have 13.4V-13.6V minimum voltage.
    If converter is turned on and you have less than 13.4V-13.6V you have an issue with converter (blown fuse, dead converter, no power to converter).. Which will require additional troubleshooting..
    Battery resting voltage below 12.8V-11V with converter turned off will mean partially or fully discharged battery or failed battery..
    Battery resting voltage below 10V with converter turned off means deeply discharged battery or completely shot battery..
Having RV issues? Connect with others who have been in your shoes.24,318 PostsLatest Activity: Sep 14, 2025
