BFL13
Oct 19, 2014Explorer II
NinerBikes wrote:BFL13 wrote:KD4UPL wrote:
Not enough voltage to charge a battery by itself. Put 2 in series and use an MPPT charge controller and it will work fine. You could put more than 2 in series depending on what the voltage limit of the charge controller is.
Two with my $13 gizmo limit at 32v almost as good as MPPT? Easier as a portable with two small panels instead of one big heavy one.
Link to your $13 gizmo unit and what it does?
Free shipping. Less than $13 in US dollars. Probably needs a fan attached to the fan connection at max amps so add the cost of a fan.
http://www.ebay.com/itm/DC-DC-15A-Converter-Buck-Adjustable-4-32V-12V-to-1-2-32V-3-3V-5V-24V-Step-Down/281206555382?_trksid=p2047675.c100011.m1850&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D25217%26meid%3D8539ba1eede94f48b9c4da74610ac108%26pid%3D100011%26prg%3D10629%26rk%3D5%26rkt%3D10%26sd%3D351129151726&tfrom=351129151726&tpos=unknow&ttype=price&talgo=origal
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
