Almot
Sep 05, 2013Explorer III
What pianotuna said - balanced wiring if you go 2*12V. For 2*6V - series wiring.
Seems like the debate "6 vs 12" is already on, so - I don't think there is much difference in 2*6 vs 2*12, if nominal amp-hours are the same in either setup. Meaning - 2*110AH @12V = 2*220AH @6V. Main consideration should be to max up the amp-hours at the given space available.
Again, if you come across some monstrous 8D :) and it fits, make sure you can lift it.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 16, 2026
