- pianotunaNomad IIIHi,
This is what is balanced and best for twin twelve volt batteries.
As it often doesn't cost a dime more to do this, I think it is worth the trouble.
If you wish to understand the "why" surf here:
correctly interconnecting multiple twelve volt batteries
Others may say it doesn't matter--but unless there is a compelling reason to not optimize charging and discharging why not do it the best possible way? - NorskemanExplorerMake the jump and install a second battery. If you need a new one I would go with 6 Volt batteries. Had 6 volt in motor homes but trailers always come with 12V.
I have added a second battery in every trailer we have owned. Needed if you run the furnace for a weekend when dry camping.
I have this set up in our fifth wheel - it is a battery box designed for 6 volt batteries. Put some styrofoam pieces in it to prevent movement of the batteries. Just in case - - - 12 Volt are connected in parallel and 6 volt will be connected in series.
- RJsfishinExplorerAmp hrs are the same 6v or 12v, if we talk group 27 12v, verses the std golf car 6v. Either will work fine. If it were me, I'd go w/ the 6'ers, but don't really know why (please don't tell me why I should or shouldn't) I used 6'ers for 9 yrs, now I'm using 12'ers, and w/o getting all tech'y there ain't no difference, no matter what !!.
But I do like the series connection on the 6'ers a little better
FYI, the 6v batteries are the same size as group 24 12v, except they are at least 1.5 inches taller - AlmotExplorer IIIWhatever fits and whatever you can lift. I wouldn't go over 62-63 lb.
- Old-BiscuitExplorer III
bob213 wrote:
Not to start the 6 vs 12 debate, but have you considered two 6's in series for more amp hours?
Can you get more AH's from 2-6v or 2-12V?
Thought you could get more AH's from 2-6V vs 1-12V.
OP is thinking about installing 2nd 12V - old_guyExplorerwhy don't you go to two 6v's
- bob213ExplorerNot to start the 6 vs 12 debate, but have you considered two 6's in series for more amp hours?
- HeelshockExplorerThat's good news. Thank you.
mena661 wrote:
If you have room for the 27, no problems using it. - Go all the way to 29 if you like. Measure first.
- mena661ExplorerIf you have room for the 27, no problems using it.
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 24, 2025
