MEXICOWANDERER
Jul 11, 2019Explorer
The studs are metric of course and 5/16" ring terminals fit the studs easily and 1/4" ring terminals no-way-in-hell.
The Chinese are infamous fraudsters. The incredibly bright 18-watt CREE lamps use a voltage regulator but draw only 12.7 watts. The Chinese sellers are too stupid to realize the low watts are a bonus not a negative. Their 10-watt chips are horribly overdriven at 10 watts. Nine point nine volts is optimum. around seven watts.
Buy Mexican or USA from Amazon instead of eBay. If the solenoid arrives with quarter-inch studs cry FRAUD to Amazon and stop payment plus give one-star. VISA is wonderful about returning your money. eBay does not like the word FRAUD in a review. in fact, they get rather hysterical.
Thanks for the heads-up Landy. 200-amps constant duty is a lot of amps. In fact, I swap out steel carriage bolts for Silicon Bronze on high amperage Leece-Neville alternators. The negative terminal stud is STEEL is 1/4" x 20.
I query vendors all the time on eBay. If the answer is SORRY WE ONLY SELL it's time to move on. Chinese electrical is dangerous and insults the intelligence of even a low brow.
I tested my recommended six ways from Sunday before recommending it. Thirty seconds at 300 amperes had an average volt drop through the device of 1.18, and the studs had no great warming. I used the BORG both power supplies in tandem to boost the voltage of the group 31 Lifeline.
There is no way in hell a Ford type solenoid can compete with a legitimate solenoid larger Trombetta. The pull-in power is greater the break retraction force is greater and I had a five-yard dumpster right outside my window with lote of failed ford type "constant-duty" solenoids. I thought silver inlaid contacts would help. They didn't. The 11180 solenoids barely beat out the copper contacts ford TYPE solenoids. The only way to increase magnetic force without increasing ampere-turns is to Use a lower value Mu metal in the electromagnet. More laminations and it means a larger structure.
Try a GENUINE 200-amp constant duty Trombetta with 5/16" terminals and enjoy the benefits.
PS: Te difference between TYCO small relays and garbage Chinese counterfeits is just as large if not greater. The NINE Beijing wanna be's lasted a few months each driving the electric fan motor of the Spirit. The Tyco has lasted SIX YEARS. I purchased TWENTY Tycos and bequeathed a sackful of garbage on a local garage. Good riddance.
As I noted earlier if the Trombetta has a sticker MADE IN MEXICO or MADE IN USA the correct solenoid will have the metric equivalent 5/16" studs.
Having RV issues? Connect with others who have been in your shoes.24,384 PostsLatest Activity: Apr 26, 2026
