MEXICOWANDERER's avatar
Jul 23, 2016
The BORG Refit 2 Pedal To The Metal
Full wave bridge rectifiers doubled in ampere capacity rated 1KV PIV
Arctic Silver transistor and heat sink thermal transfer. Massive finned heatsinks heliarced to Megawatt cases.
ON upgrade bi-polar transistors and all Panasonic ESR capacitors, now.
Fan shrouds chopped out and wire computer fan guards are now in place.
10.8 to 15.88 voltage span.
Da Rumble En Da Jungle. The device weighs 10.82 pounds.
120vac source has all the de-spiking tricks now
Quad redundancies of
Gas Discharge tubes, avalanche rectifiers and 20mm MOVS.
For EACH Megawatt. ie, 8 total avalanche rectifiers, etc. 2-amp rice grain fuses on each device. 24-in-all.
Feels GOOD to actually DO something again. A complex project successfully finished. Some people squander huge amounts of money on cigarettes,single male Scotch or faux-beer. I squander my money on NERD stuff.
  • You were able to tig weld heat aluminum sinks to the megawatt aluminum casings with arctic silver thermal compound in between them?
    I used the Arctic silver 2 part thermal epoxy on my Meanwell. Had to avoid the transistor bracket screw holes.
    Amazing how much ambient temperature affects all the heat producing things I now have temperature sensors attached to.
  • At 88 volts AC RMS, the BORG (A) Megawatt will develop 34 amps max.
    I got tired of dealing with moronic grade trash. Durable, light, versatile was my guide-on.
    Best part is a puny Honda 500-watt generator can generate precisely and exactly it's maximum possible potential by dialing back the voltage, either (A) or (B) Megawatt unit. I am going to connect this critter in-series to A HUNDRED WATT LIGHT BULB, meaning throttling input power to A HUNDRED WATTS TOTAL and see what kind of output I can get. Maybe three or four amps? Dunno...
  • Well done... My Sears Crapsman 2/10/60amp weighs more than that and will only hold 60a for a few seconds before becoming uncomfortably warm.
Having RV issues? Connect with others who have been in your shoes.24,333 PostsLatest Activity: Nov 06, 2025
