MEXICOWANDERER
Feb 09, 2018Explorer
The Golden Age Of Tool Instruction Printed In China...
Some assembly required never made me smile.
Then there is this bit of wisdom using an electric drill to fasten pop rivets.
1.Small size and easy to carry, more efficient.
2.Lower noise.
3.A horde of rivets function, pull a good effect that it does not waste a rivet.
3.Can complete drilling, pulling rivets and screwing, as long as you have a drill.
4.Contrast with the traditional riveter:
1)Hand riveters is laborious and inefficient.
2)Traditional electric rivet gun is heavy, not portable, noisy and drop rivets. The internal structure is easily damaged.
Usage:
1.Hold the riveter body, drill reversed.
2.When you hear "da da da", the screws can be inserted into the nozzle.
Using the wrench to install the right size nozzle.
Using the wrong size will get stuck.
2.Lower noise.
Usage:
