- Chris_BryantExplorer II
vtchris wrote:
Awesome! Is the white plastic cover in the center top of this photo? And the silver block inside it? Do the notes in the photo apply to this discussion?
No- those notes are from another thread, though they do apply to removing the thermostat. The plastic cover is removed in this picture- this drawing will kind of show it- it is the cover with the 2 #1 screws in it-
- vtchrisExplorerAwesome! Is the white plastic cover in the center top of this photo? And the silver block inside it? Do the notes in the photo apply to this discussion?
- Chris_BryantExplorer IIYour RM2410 does not use a thermister, it uses a dual mode thermostat, single thermostat for both LP and electric. It is one the rear of the refrigerator, with a shaft running from the knob back to the thermostat. It has a small capillary tube which runs in to the cabinet and is attached to the fins under a metal plate.
This part on the back of the refrigerator is under a white plastic cover- the silver block in the center is the thermostat itself.
- vtchrisExplorerEven at lowest setting, the fridge temp is 20 degrees. According to the manual, I need a new thermostat, but I don't know where it is located or what it looks like.
- Thermistor is the thermostat.
You can adjust temperature by moving the unit up to cool more down to cool less.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
