Sparksvonrou's avatar
Sparksvonrou
8 years ago
Thermostat temperature sensor
I have a intellitec electronic climate control for my heating and air conditioning. Where is the actual temperature sensor for that located since the intellitech is mounted inside of the wall. I'm asking because the temperature variation is quite extreme inside of the coach. Has anyone successfully changed this out for a modern thermostat, for example and electronic one that we can set date and time for temperature changes?
  • Thanks! Found them. So is there wiring diagrams for this system anywhere? 97 Southwind Storm 35S.
  • Year and model of coach,? Somebody with similar coach can tell you where they are located
    Little brown oval thing , with a slot in it all the way around
    The switch on the wall is just the setting control
    There electrical control unit is mounted at or near your 120v circuit breaker box
    Typically the rear of the coach bath and bed, is on (1) section of the control ,the rest of the coach on the other section
    The temp up in the front by the windshield or slide out, will always be different than the bedroom, even with the exact same settings
    The front has a larger Warmer area to cool
    setting on 'Auto cool' will give a wider swing/variation than
    just setting on high cool
    its in the manual, where it describes operation of the different modes
