Old-Biscuit
Aug 01, 2017Explorer III
Thetford doesn't have a 300
Dometic/Sealnd has the 300 series
Toilet seat bolts have snap in covers....remove them, use a screw driver to tighten bolts while holding nuts with your hand
Just reach under along side sliding hand back until you can grip nuts.
Just plastic bolts/nuts and can be tighten by hand
Otherwise you will need to disconnect water supply line, remove the hold down bolts in base, lift toilet up and remove.....careful of floor flange gasket
Tighten seat bolts/nuts ...reinstall...same floor gasket IF in good shape.
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 15, 2026
