Old-Biscuit
Nov 27, 2015Explorer III
Direct replacement (water supply will need modified regardless of toilet)
Thetford Aqua Magic Residential, Style II and Style Plus which means Dometic/Sealand 300/310/320 Series will also work
Vacuum breakers can easily leak..they just use a flapper that closes hole in top when water pressure is present then when water pressure drops off the flapper is no longer held closed and air gets pulled in.
IF flapper fails to close water leaks out top of vacuum breaker.
Clean water puddle can be from vac breaker, water supply cartridge, hose clamp.
Place toilet paper around suspected components and see which one ends up being a wad of wet TP
