GlennLever
Feb 20, 2014Explorer
So.....
I have an answer from cummins and an answer from Syracuse, NY | Cummins Northeast, LLC
They contradict each other.
Cummings says
"Good Afternoon Glenn,
The part that you are referring to in the pictures, looks to be a temperature sensor for coolant. I had go ask someone more more technical skills than I do. He also stated that the wiring question is kinda hard to figure out. I was advised that the sensor probably only has 1 wire, but there could be other leads that are connected to it, but that is usually done by the mechanic, not by the company. By having the leads on the sensor, it may have helped someone with the set up of the wiring so that they wouldn't have to splice somewhere else.
I hope this helps
Thank you for contacting Cummins.
Mark
Customer Care Representative
If we have misunderstood the information in your communication or you have additional questions please feel free to respond to our support staff by e-mailing powermaster@cummins.com or call Monday through Friday, 7 a.m. to 7 p.m. ET at 1-800-DIESELS (1-800-343-7357). If you are located outside of North America, you can reach us at 812-377-3000.
For authorized service center locations please visit:
Cummins.com
Cummins.com
Everytime.cummins.com"
Syracuse, NY | Cummins Northeast, LLC says
It is a solenoid in the air intake heater system. Judging from your photo's, it should have 2 wires connected.
Matt Barkley
Service Writer
Cummins Northeast LLC
6193 Eastern Ave.
Syracuse, NY 13211
Phone: (315)437-2751 ext 5103
Direct line: (315)410-7523
Fax: (315)437-8141
One says one wire the other says two, one says temp sensor the other says solenoid.
Syracuse also sent along a diagram (attached) which describes the part as a solenoid valve, but no wiring diagram is included.
Cummings says
I hope this helps
Mark
Cummins.com
Cummins.com
Matt Barkley
Service Writer
6193 Eastern Ave.
Syracuse, NY 13211
Fax: (315)437-8141
Having RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jun 12, 2026
